Author Topic: Brake pad warning wire  (Read 4489 times)
« on: October 06, 2025, 11:20:57 AM »
Does anyone know if you can buy these anywhere?
Re: Brake pad warning wire
« Reply #1 on: October 06, 2025, 10:05:06 PM »
In the past I've seen them come with brake pad sets but
not recently.
If you've got new pads which I'm sure you have, you'll not need it in a long
time.
Just keep a look out on all those marketplaces.
N
« Reply #2 on: October 06, 2025, 10:28:40 PM »
Hi Mark
As Nigel says, the odds on you wearing out a set of new front pads is very doubtful.
« Reply #3 on: October 07, 2025, 12:32:28 AM »
Just for authenticity tbh
« Reply #4 on: October 07, 2025, 09:48:18 PM »
I would try making one or two.
2 pack epoxy comes to mind, filed down to a firm fit.
Protruding around 3mm from the pad back plate.
N
« Last Edit: October 08, 2025, 06:05:11 PM by Nigel »
Offline JASPER_40
  • Country: au
« Reply #6 on: October 09, 2025, 09:08:19 AM »
I just purchased some new old stock Bendix brake pads on ebay as they came with OE brake wear indicator end caps.....just an impulse buy simply because they had the wear caps included.
However, I have recently purchased some break wear sensor wires for an older Meredes which have a similar ends that slots into the brake pad hole. The Mercedes sensor wire is made to connect with a bullet connector about 6" from the caliper and so I simply made a wire with a female bullet terminal to suit.
Not the same but will do the job if you get stuck and want the wear sensors to work.
Steve
P.S. Also in the interests of authenticity, I have since replaced the interim Mercedes wires with the original Lancia wires utilising the new caps I got with the Bendix pads
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #7 on: October 09, 2025, 10:05:34 AM »
Thanks for that.  I will look into it
M
