Author Topic: Air Conditioning  (Read 6206 times)
Air Conditioning
« on: October 18, 2025, 03:26:52 PM »
Has anyone got a pictorial layout of the system so I can sort out where on the bulkhead the pipes come through to the cabin?
Re: Air Conditioning
« Reply #1 on: October 18, 2025, 04:52:38 PM »
As far as I recall Guy, they came through the firewall either side of the brake servo. I think Jasper has an a/c car, maybe he can shed some light?
N
« Last Edit: October 18, 2025, 04:54:17 PM by Nigel »
« Reply #2 on: October 18, 2025, 05:23:12 PM »
Thanks Nigel - can you recall if it was above or below the servo? I was looking at below the servo this morning but I'm a little concerned that this might be fouled by the steering arms unless it's a really tight 90 degree fitting. I probably need to buy a couple of unions and see! No holes drilled yet.
Offline JASPER_40
  • Country: au
« Reply #3 on: October 19, 2025, 03:27:26 AM »
Hi Guy,
These are the 2 aircon coolant pipes on mine (yellow). There is also the vacuum control pipe from the vacuum tank that goes through the bulkhead (red)
Is this what you are looking for ?
« Last Edit: October 19, 2025, 03:37:24 AM by JASPER_40 »
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #4 on: October 19, 2025, 08:48:48 AM »
Just like the above photo Guy.
It's quite crowded in that area and getting
grommets seated correctly will be a challenge.
N
« Reply #5 on: October 19, 2025, 09:31:20 AM »
Thanks both! I like a challenge but a solution that doesn't involve cutting new holes in an existing bulkhead is a winner for me! I guess I also got fixated on the need to use a neat T7 Design bulkhead connector and that's not necessary now.
« Reply #6 on: November 09, 2025, 02:31:12 PM »
I think I mentioned this on a different thread but it appears appropriate for here, apologies that this is a bit rough and ready and it's possible that some pages might be in the wrong order. There is a small amount in English that is probably duplicated in the Italian stuff.
https://photos.app.goo.gl/UATJJ6bvskZzpLXN9
