Author Topic: PS Steering rack gaiters and then maybe changing/bleeding oil  (Read 3093 times)
« on: November 05, 2025, 09:41:52 AM »
Morning, whilst underneath the other day I noticed a tiny hole in my PS rack gaiter.  What the best/nicest/quickest process to change this, anyone been there before?  Haynes gives the impression its not silly hard to remove the whole rack, is it and should I?
I will have a proper look at what needs to come out and how next time I am working on it.  And next question, changing fluid, is it a case of draining as much out and adding new?
Re: PS Steering rack gaiters and then maybe changing/bleeding oil
« Reply #1 on: November 05, 2025, 12:21:27 PM »
Depending on where it is and how bad a bicycle puncture rapir kit can work wonders here!
Removing the rack is not too difficult  Access is a bit of a pain but not too bad. 4 bolts, the steering column and the hydraulic fluid connections then it slides out through the wing.
« Reply #2 on: November 05, 2025, 01:55:17 PM »
summer job maybe :-)  Thanks for this.  I might look at changing the fluid though.
« Reply #3 on: November 05, 2025, 09:49:15 PM »
I found I could change the near side gaiter in-situ when mine
failed the mot a couple of years ago. Fairly straightforward.
I recall thinking that I could probably do the other one from the
same nearside access, but bit more of a reach.
There's no fluid inside these, they are dust covers, so as Stuart suggested, a patch to fix
a pinhole would appear acceptable. Even a small dollop of CT1 might do, after good cleaning.
If your fluid is still red, or even slightly off-red, it's good. You should get a reasonable
indication of state by visible debris in the reservoir. I would change it by several evacs/top ups
of the reservoir. Doing it this way avoids getting any pesky air in the system.
N
« Reply #4 on: November 06, 2025, 03:11:39 PM »
Thank you this is what I want to hear :-)
I will take another look and repair until the Spring of something else is in bits in this area, could be when I do front shocks.
What fluid did you use in the end, I did find a few posts on the subject but no actual decision whats best?
« Reply #5 on: November 06, 2025, 08:35:06 PM »
Regular ATF is fine.
