Author Topic: Head light nylon captive nut  (Read 1611 times)
Offline lancialulu
« on: January 10, 2026, 02:58:11 PM »
Does anyone have a source for this part or has 3D printed it (in nylon)
Or do folk use an M6 cage nut and keep it well greased?
Re: Head light nylon captive nut
« Reply #1 on: January 10, 2026, 10:16:05 PM »
Can you get a better photo?
Is it for the Siem lights?
Offline lancialulu
Re: Head light nylon captive nut or headlamp assemblies wanted
« Reply #2 on: January 11, 2026, 02:29:01 PM »
Hi Peter
I have this system but on closer examination a PO has butchered it to fit Wipac bowls and chrome rings. Most of th ewipac bowls have given up the ghost as most adjusters have sheared off....
Not sure which path to take (cheapest is replace the wipac bowls etc) but the headlamps are not correct either (H4 and H1 with pilot lights) They will work but not what I want.
So am looking out for a good set of headlamp assemblies.
Tim
Offline VXdeMayo
« Reply #3 on: January 11, 2026, 03:35:36 PM »
I might have one side that is ok. Not rusty but a bit tarnished?
Is it Carrelo or Siem mount pattern required?
« Reply #4 on: January 11, 2026, 04:39:00 PM »
Hi Tim
Those backing plates and plastic clips are the Siem ones. I have 3 spare clips you are welcome to which were gifted to me by Guy.
The problem you will most likely find is that the Siem style mounted lights are almost impossible to find. You can find the odd one, but I never found a complete set for my HPE and as such I had them re-silvered at not an inconsiderable cost as they were re-usable, most however are not. You will also need the stainless rings and plastic inserts for them which again may be an adventure to find.
Personally if you do not need the auto headlight adjustment found on the HPE and Saloon then I would switch to the Carello setup which is so much easier to fit modern lights to.
If you are after a set of backing plates and bowls etc, then I may know a guy who still has a pair I sold him and he never used from memory. also the various Coupes breaking may have Carellos, though I guess they may have the single combined unit which is different again.
