Author Topic: Sill Cover End Protectors  (Read 291 times)
« on: February 05, 2026, 02:23:44 PM »
Steve ((Jasper_40) has kindly sent his design for the end protectors for the stainless sill covers. I modified them a little to complete the small end cap as I learnt he designed it from photos, not an having an original which was pretty impressive. Originally Steve suggested to use PETG, but the originals are both flexible and will not damage the paintwork, so I tried TPU which worked out really well and is very similar to the original material used. I found that the originals have all shrunk over time and hence having a properly fitting pair quite attractive....
I have uploaded the .STL file to the downloads section, remember you need a mirror image to complete the pair....
Offline deks
  • Steve Hudson
Re: Sill Cover End Protectors
« Reply #1 on: February 05, 2026, 07:44:52 PM »
if you're making these Peter to sell, I'd be happy to buy 4 from you.
Offline Clifford
« Reply #2 on: February 06, 2026, 02:36:06 PM »
Were these protectors standard or of the factory port is it an improvement which Steve designed?c
« Reply #3 on: February 06, 2026, 02:46:28 PM »
They were originally on the covers from the factory otherwise you had a metal edge which could damage the paintwork.
Offline Clifford
« Reply #4 on: February 06, 2026, 03:19:37 PM »
Ah. I never knew that.
I would be interested in purchasing some from you too please Peter.
C
