Author Topic: My Beta restoration  (Read 16707 times)
Offline Carlwil10
Re: My Beta restoration
« Reply #60 on: September 09, 2026, 05:47:11 PM »
No worries Guy, I think I'll  be cutting those little bits out anyway to get behind them
Offline deks
  • Steve Hudson
« Reply #61 on: September 09, 2026, 06:26:01 PM »
Some big bits missing there Carl. Are you replacing the vertical part of the inner wing? Or fabricating it?
Apologies, still got a bad back so I haven't had a chance to photograph the underside of my car for comparison!
How similar is the Spyder front end as Mine is on its side and easy to photo. I will in time be cutting the front end off to sell when/if some needs bits. Ive just got to work out where I either unstitching or cutting it. Reminds me best invest in some new spot weld drill bits mine are years old and probably blunt
« Reply #62 on: September 09, 2026, 09:15:54 PM »
The Spider front end is the same as the Coupe,, though Carl's is a pre facelift, so maybe the odd small difference.
Offline Carlwil10
« Reply #63 on: September 10, 2026, 07:13:59 AM »
I noticed that this area on Guys car is different to mine. It may have been changed at the factory as on mine there's an area that cant be treated and would get dirt build up behind it. I'll be cutting it off to clean it all up and treat.
Carl
« Reply #64 on: September 10, 2026, 07:53:14 AM »
Hi Carl
Also Guy's car will have plastic wing liners, yours originally did not, though it may be possible to retrofit them.
I have a spare set if you want to give it a go.
Offline Carlwil10
« Reply #65 on: September 10, 2026, 10:25:37 PM »
Hi peter
Yes thanks I'll have and see if I can get them to fit thanks
Carl
Offline Carlwil10
« Reply #67 on: September 21, 2026, 01:48:37 AM »
Thanks guy, that's the same as yours so I think I'll cut my section out.
Carl
Offline Carlwil10
« Reply #68 on: October 04, 2026, 04:31:10 PM »
A bit more progress on my coupe. The first bit of epoxy primer on. Now what's people's thoughts on using rivnuts along the top to bolt the wings on.
Carl
« Reply #69 on: October 04, 2026, 05:36:26 PM »
That's what I've used Carl!
Offline Carlwil10
« Reply #70 on: October 04, 2026, 06:48:56 PM »
Ok Guy, I'll go with them then
Carl
« Reply #71 on: October 04, 2026, 10:15:41 PM »
That sounds like a win! :-)
