Author Topic: Borletti Vegliaflash digital clock  (Read 5732 times)
Offline Luigi
« on: March 02, 2026, 08:22:56 PM »
I have one of these digital clocks in my ‘79 Spyder, version number 82378047.  It keeps time well but I would LOVE to have all of the bars working!
Has anyone found a clock restorer who will go anywhere near this particular model?  They were the preferred make for Ferrari, Maserati and Fiat back in the day but a brief look on FerrariChat etc. hasn’t shown much about any restoration projects of these clocks.
Or….is anyone here a whizz with a soldering iron and got their own clock working?
Rich (aka Luigi - it’s a long story)
1979 Beta Spyder 2000
Re: Borletti Vegliaflash digital clock
« Reply #1 on: March 03, 2026, 08:42:03 AM »
Let me try a spare or two and see if they work. I'm not planning on using them so you would be welcome to one.
« Last Edit: March 03, 2026, 09:12:36 AM by peteracs »
« Reply #2 on: March 06, 2026, 02:03:35 PM »
Sadly my clocks are both dead... Can't help in this case.
« Reply #3 on: March 06, 2026, 02:31:13 PM »
Its it the same as the Delta one?  Picture would help for those of us with earlier cars!
Offline lancialulu
« Reply #4 on: March 06, 2026, 06:16:17 PM »
Its probably the same as S2 gamma
« Reply #5 on: March 06, 2026, 10:34:44 PM »
A photo would be good to see if I have one?
Offline Luigi
« Reply #6 on: March 06, 2026, 11:09:23 PM »
Thanks for looking.
It is, I think, a unique design as the script is below the digital display.
Offline stableblock
« Reply #7 on: March 07, 2026, 07:28:07 AM »
Have you got one out of the car?  Is it easy to open so we can see the inside?  The display leds tend to come as an integrated unit and it would be necessary to source a new one.  If you can post some pictures I might be able to track one down.
Offline Ics19
« Reply #8 on: March 07, 2026, 10:23:49 AM »
While the bezel is slightly different, I can't believe the inside is any different to the X1/9 1500 or Montecarlo S2 unit.  It might be as simple as a dry joint on one of the segments, but not easy to get to all of them. New units here:
https://www.midwest-bayless.com/p-5781-4426031-oe-digital-clock-veglia-fiat-bertone-x19-1979-88-124-spider-1983-85-oe.aspx
Here's a pic of an X1/9 inside for comparison.  You'll likely find used units, but not cheap and just as likely to fail.  I'd take yours apart first and wiggle the display board to see if things change, then run a soldering iron over the joints.  You can power it up simply with a 12v supply.
« Reply #9 on: March 07, 2026, 11:48:51 AM »
When you say dead, how did you connect them to test?
« Reply #10 on: March 07, 2026, 11:49:23 AM »
Yes, I have one and appears to be working.
Offline Luigi
« Reply #11 on: March 08, 2026, 11:38:30 AM »
Thanks all for being as helpful as ever.
I’ll remove my clock first, run a soldering iron over it and see if I can improve the display. Would be a shame to throw it out at this stage as it keeps time well.
The car’s up at Omicron at the moment so I’ll have a look when I get it back.
