Author Topic: Fuel pump fuse location  (Read 1672 times)
Offline Joe912/62
  • Country: ca
« on: March 15, 2026, 03:23:18 PM »
Where is the fuel pump fuse located in a 82 Zagato with fuel injection?
Re: Fuel pump fuse location
« Reply #1 on: March 15, 2026, 09:44:38 PM »
Joe,
In the diagram it shows a fuse between the I.E. relay and the alternator.
I can't help with the location but it appears to be a stand-alone fuse.
However, you may well have a secondary fuse box on the left side inner wing, it
could be there.
Hope this helps a little. Nigel
Offline Joe912/62
  • Country: ca
« Reply #2 on: March 15, 2026, 10:50:44 PM »
Yes I do have a secondary fuse box but I have no reference to what each fuse is for. There are 4 bullet fuses in the left side and 16 on the main and don’t have any reference for those either. Do you have something in your electrical drawings?
Offline neromoto
« Reply #3 on: March 16, 2026, 02:45:22 AM »
Are you referring to this fuse?
My Beta has a carburettor, so I’m not actually sure.
The Gamma’s fuel injection uses the same system, and there is a single fuse holder for that fuse on the right-hand side of the engine compartment, near the wing.
On the layout diagram, it appears to be located near the pump.
« Last Edit: March 16, 2026, 02:55:49 AM by neromoto »
Thema 8.32 S2 1990
Gamma Berlina S1 1978
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
