Author Topic: The Lancia torch accessory  (Read 9309 times)
Offline Clifford
« on: April 30, 2026, 03:53:21 PM »
Hi all
I have recently bought one of the above just for a bit of historic completeness with the car.
I see there are various references to these over the years but no definitive way to refurbish them trust I could see unless I missed a post.
The torch I have got seems to be in reasonable condition body wise.
The head unscrew and I can get the bulb out.
The switch works and the body slides back and twists ok.
The battery looked as if it might have leaked inside and I am assuming is dead after all this time.
What I would like to do is get the battery out without damaging the switch mechanism and see if I can get a modern rechargeable battery to replace it.
So if anyone can advise how to get the battery out I would appreciate it please.
Also if anyone has sourced bulbs and batteries to fit, it would be good know where from as that would save a lot of tracking down if Indeed they are even out there.
Many thanks
C
Re: The Lancia torch accessory
« Reply #1 on: April 30, 2026, 04:30:08 PM »
You should have looked in Electrical.   Alan recently posted this
https://lanciabeta.co.uk/forum/index.php?topic=5466.0
I think I was bidding against you :-)
Offline Clifford
« Reply #2 on: May 01, 2026, 08:13:44 AM »
Hi yes I saw this but doesn't really give me the information I am looking for but in hindsight I should have probably added to this post rather than starting a new one.
Ah bidding on Ebay. Sorry you lost out.
C
« Reply #3 on: May 01, 2026, 10:27:04 AM »
When I've got a minute I'll do a how to on this thread
Offline Clifford
« Reply #4 on: May 02, 2026, 07:38:25 AM »
Thank you RossaCorsa
Trust would be much appreciated
C
Offline VXdeMayo
« Reply #5 on: May 02, 2026, 06:46:34 PM »
Rossocorsa I would also like to see how to restore my torch. Put it on charge but no improvement. I also need to source a replacement bulb.
Look forward to your information. 👍
Offline Clifford
« Reply #6 on: May 03, 2026, 09:08:44 AM »
I think I have sourced a bulb but proof of the pudding is when it arrives.
Once I have confirmed it's correct. I will post the link to the supplier.
C
