You're correct that it should take 1.8 litres.
If it took 2.5, it's probably overfilled, question is why?
Is it possible you misjudged the quantity?
Did you fill via the dipstick hole? That's the only spot available.
Your measurements match a dipstick I have here.
I would check it again after a drive, after letting it settle.
