Author Topic: show me your throttle cable please?  (Read 1480 times)
« on: May 26, 2026, 11:30:00 AM »
My cable seems way to long..  What does yours look like?
M
Re: show me your throttle cable please?
« Reply #1 on: May 26, 2026, 11:56:22 AM »
Not like that. I suspect your car has a LHD cable fitted?
Offline lancialulu
« Reply #2 on: May 26, 2026, 12:37:34 PM »
could be a VX cable.....
« Reply #3 on: May 26, 2026, 02:01:03 PM »
Hi Mark
This is typically how it goes. ( photo from internet)
Offline deks
  • Steve Hudson
« Reply #4 on: May 26, 2026, 02:49:53 PM »
i like that polished water pipe across the top of the head.
Offline lancialulu
« Reply #5 on: May 26, 2026, 03:48:22 PM »
It must be the heat but I like the novel tool storage!
« Reply #6 on: May 26, 2026, 06:55:13 PM »
Your cable is too long.
I can't photo it right now but mine takes a fairly straight, slightly curvy route
from the bulkhead.
Yours even looks too long to be an LHD version, so if it came with the car
those Seffricans fitted what they could find.
You may be able to have one made up by a specialist.
N
Offline lancialulu
« Reply #7 on: May 26, 2026, 08:59:09 PM »
Have you tried Omicron??
« Reply #8 on: May 26, 2026, 09:58:04 PM »
Ricambio in Surrey has 3 different choices listed, depending
on the length. It says LHD only, but if it fits better than what you've got......
N
« Reply #9 on: May 27, 2026, 11:08:22 AM »
Good one Nigel, I will take a look
« Reply #10 on: May 27, 2026, 01:01:36 PM »
I'll measure and photo mine when I get home later today.
Offline JASPER_40
  • Country: au
« Reply #11 on: May 27, 2026, 03:30:08 PM »
Yep, pretty sure you have the wrong size throttle cable in there.
Also, the cup holder you have in your expansion tank is just so cool....very handy....want one.
Steve
« Last Edit: May 27, 2026, 03:32:25 PM by JASPER_40 »
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #12 on: May 27, 2026, 05:07:57 PM »
I didn't measure it but the routing is similar to Steves above.
You will see an extra bracket I fitted to align the cable with the entry point
on the bulkhead. I felt it may prevent premature wear.
« Last Edit: May 27, 2026, 05:10:18 PM by Nigel »
« Reply #13 on: May 27, 2026, 10:25:46 PM »
Like the bracket TVM
Anyone have the process for removing the cable?  Never done it before, I am guessing limbo your head under the dash ;-)
Offline JASPER_40
  • Country: au
« Reply #14 on: May 28, 2026, 03:15:38 AM »
As for a procedure to load in a new throttle cable.....I would definitely attach a "pull through" string so that you can pull a new cable through the same path. Not sure which end to pull but the cable ends are not that big so should be quite straight forward.
I have attached a pic of a replacement cable which I never needed / fitted (impulse spares purchase). Looks like it may be easier to pull the cable out from the engine bay side. The cable is approx 65 cm end-to-end.
I did replace my speedo cable which was a very tense operation as the ends of the speedo cable are quite bulky and therefore difficult to thread. The pull through string saved the day for sure.
Cheers,
Steve
« Last Edit: May 28, 2026, 03:34:07 AM by JASPER_40 »
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #15 on: May 28, 2026, 03:45:49 PM »
Found my cables. None new but I do have two the same length as listed above. If you haven't sourced one yet Mark I can pop it in the post next week?
« Reply #16 on: May 28, 2026, 04:31:35 PM »
That would be amazing Guy, please let me buy it.  I wasnt rushing as it works.
Steve thanks for the info, yes Speedo cable is on my sh£$ jobs on a Beta for sure.
