Author Topic: Mystery part, any guesses ?  (Read 3854 times)
Offline JASPER_40
  • Country: au
« on: July 15, 2026, 12:26:53 PM »
I have this mystery item located in the air box which is sits inside the air filter space. What do you think it is for ?
The item has 2 pipe connections beneath the air box which have been capped off on my car. They look like vacuum connections maybe ?
Thinking that it may be something to do with the emmission control system that used to exist for my Australian delivered car which has long since been deleted.
Cheers,
Steve
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
Re: Mystery part, any guesses ?
« Reply #1 on: July 15, 2026, 04:45:05 PM »
It is a sort of vacuum switch for the diaphram that switches over the airbox air intake flap between hot and cold air. No real need for hot air in our warm world car use so a good thing to remove and isolate.
« Reply #2 on: July 15, 2026, 05:45:28 PM »
whole lot is gone from my SA car, interestingly the manifold metalwork has the hose connection blocked off and another SA Beta that was up for sale a few months back had the same.  I wonder if its deleted from new?
« Reply #3 on: July 15, 2026, 08:42:44 PM »
I always thought that twin cams get carb icing at winter temperatures on the motorway? I've definitely experienced it myself in the past.
Offline JASPER_40
  • Country: au
« Reply #4 on: July 16, 2026, 09:06:08 AM »
"Carb Icing".....alien concept to us Western Australians.  ;D
« Last Edit: July 16, 2026, 09:19:17 AM by JASPER_40 »
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
Offline JASPER_40
  • Country: au
« Reply #5 on: July 16, 2026, 09:18:27 AM »
Yeah, I reckon this must be right. There is a vacuum take off for the air box diaphragm that works the actual flap but I can't work out how the vacuum switch is plumbed in to the diaphragm unless the vacuum supply first goes through the switch and then onto the diaphragm. The ID of the components are quite different....there may be other components missing ?
Not seen a pic anwhere of how this flap is suppsed to be connected / operated.
It would never be actuated in this climate but might be nice to get it re-commiossioned just for the bragging rights. 8)
Cheers,
Steve
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #6 on: July 16, 2026, 09:23:42 AM »
I'll send you a picture let me look it up. If you only use the car in nice weather it's not an issue but if you drive at low external temperature at constant high speed it can be.
Offline JASPER_40
  • Country: au
« Reply #7 on: July 16, 2026, 09:57:57 AM »
AI just found this for me ....
How the Pre-Heater Vacuum System Works
The Vacuum Source: A vacuum line connects the intake manifold to a temperature sensor (thermoswitch) located inside the air filter housing.
Cold Engine: When the engine is cold, the sensor is open. This allows vacuum to pass through to a vacuum actuator (servo) mounted on the air cleaner snorkel.
Flap Activation: The vacuum pulls the actuator, closing off cold outside air and opening the flap to pull hot air off the exhaust manifold (via the pre-heater stove pipe).
Warm Engine: As the engine warms up, the sensor detects the increased heat and closes, cutting off the vacuum. A spring then returns the flap to its rest position to pull in cooler, denser outside air.
Modifications: In many warm climates, Betas operate perfectly fine without the pre-heater stove pipe. Some owners permanently remove the pre-heater tube and block the vacuum line to clean up the engine bay, as it is only strictly needed for freezing climates and strict emissions testing.
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
Offline JASPER_40
  • Country: au
« Reply #8 on: July 17, 2026, 03:19:48 AM »
Ok so AI also tells me that the way this works is that the vacuum from the base of the carb is connected to the thermoswitch in the air box which is then connected to the flap diaphragm.
Mine were all capped off and I have made the plumbing connections as suggested and now will test it somehow, It will never actuate the flap due to the climate at least it is connected.
Cheers,
Steve
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #9 on: July 17, 2026, 07:27:21 AM »
The official explanation, I think it is a worthwhile feature for most people and a lot better than the flip over summer winter approximation.
Offline JASPER_40
  • Country: au
« Reply #10 on: July 17, 2026, 08:33:40 AM »
Just excellent...thanks for the good info.
So, my vacuum setup is now that the vac connection is between the take-off on the inlet manifold and the thermoswitch in the airbox, which in turn is connected to the diaphragm for the hot/cold vane actuator on the airbox...as per Rossocorsa's post above.  (y)
The vacuum port at the base of the carb is now connected to the smaller bore crankcase vent junction underneath the airbox...as per the Emissions control diagram in the Haynes manual.
My vacuum system was really messed up by a previous owner down the line who just blanked everything off and made some dubious connections. However, the engine ran fine before these corrections and hopefully will run even better now. Just waiting for some parts to arrive before I can test.
In the interim, I am going to have a play with my smoke machine to establish the integrity of the vacuum system.
Cheers,
Steve
UPDATE FOLLOWING SMOKE MACHINE TEST :
I tried to feed smoke into the system using a piece of vacuum pipe which was originally used (incorrectly) to plumb the base of the Carb into the inlet manifold, a seemingly pointless connection. This pipe was blocked as a PO had pushed a ball bearing into the pipe, probably to use as a capping device for the aforementioned vacuum connections...... :-X
« Last Edit: July 18, 2026, 08:35:51 AM by JASPER_40 »
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
Offline JASPER_40
  • Country: au
« Reply #11 on: July 18, 2026, 05:27:55 AM »
Flame trap missing !!
During the course of re-routing the vacuum lines to the air box, I noticed that there was no flame arrestor/trap inserted in the top end of the crankcase breather pipe. I had thought it might be in the other end of the pipe but can't check this too easily as the other end is hidden deep underneath the intake manifold....so I will assume it is missing.
I understand that the point of this flame trap is to stop the ignition of oil vapours in the event of a carb backfire....which could, in turn, cause an explosion in the crank case and damage the crank seals.
Is this just an overdramatisation ?
I have ordered a flame trap regardless.
Any thoughts or anecdotes ?
Cheers,
Steve
« Last Edit: July 18, 2026, 08:30:19 AM by JASPER_40 »
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
