Author Topic: Windscreen wiper / washer stalk  (Read 38 times)
Offline JASPER_40
  • Country: au
« on: October 29, 2026, 07:02:54 AM »
I designed, printed and sold this replacement wiper stalk for a Lancia Gamma. I think it is virtually the same as the Beta and quite possibly interchangeable  as it is ??...works just fine on the Gamma trafficator.
I have seen pics of one for a Beta coupe / HPE and the only difference I can see is the very end of the "ear" on the side with the 2 poles / sliding connectors seems to have the corner removed. Wonder if this is to prevent it from catching on the steering column cowling ?
I have reached out previously to see if anyone is prepared to give up a broken trafficator so I can test fit and re-work a beta coupe specific item but so far no offers. I am reluctant to disassemble the one on my S4 coupe as it is working fine and I dont want to break it or lose any of the springs inside the wiper body. With something like this it is essential to have an example to copy, test fit and stress test.
Anyone got a broken S2 trafficator I could buy ?
The pic shows the components and a couple of assembled stalks with a 6.3mm aluminium rod (Should be painted black for the Beta)
Steve
« Last Edit: October 29, 2026, 07:26:16 AM by JASPER_40 »
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
Re: Windscreen wiper / washer stalk
« Reply #1 on: October 29, 2026, 03:20:03 PM »
I have two spare.  One is working but super old and messed about with (opened up and 'fixed') and a new one from DG Rally I bout a year or so ago and has a fault.  I was going to open it up and try and fix sometime.  I am in the UK and you are in Aus right?
