Author Topic: Beta Coupe Vacuum Heater Controls Diagram  (Read 540 times)
Offline DaveFoster3029
  • Country: au
« on: October 31, 2026, 06:33:28 AM »
Hi All
I'm trying to repair my heater controls. Forty years of other peoples bodges and neglect have not been kind. The switch block is quite complex and is a mix of electrical and vacuum switches
Is there a diagram of which hose (blue yellow black etc) from the heater control goes to each box flap control ? I've tried trawling through the web and all the manuals I have but there is nothing to see. It must be in a manual somewhere.
I have the dash out as it is cracked (I have a refurbished one) and I could see that much of the vacuum stuff was not connected. I can't tell either if the water valve (on right side lower of heart box) should be vacuum or cable. I think this should be vacuum but has been replaced with a 'cable' one ánd tied open. There is no control to match a cable operation so it must be from the 'MAX' A/C setting that should shut off the hot water (maybe)  :-\
I have some certainty that the black pipe connects to the top right of the heater box which must be the inlet flap under the wipers
There were a lot of broken parts on the heater box and the cable control for the temperature slider.
I've fixed these but need to work out where the vac lines connect. I have a vac pump so I can test it while its in bits
I think the electrical connections will be OK but it would be nice to know for sure.
Dave F
Dave Foster
2 x Beta Coupe 2l,
Previously in UK
1.3 Saloon 1979
1.6 Saloon 1977
Alfasud 1.2 1976 (rustier than a Lancia LOL)
Re: Beta Coupe Vacuum Heater Controls Diagram
« Reply #1 on: October 31, 2026, 03:01:28 PM »
Hi Dave,
I've had a look in my Australian Handbook supplement and there's
nothing that would help in there.
When I removed the a/c system I'm sure I took out an inline vacuum hot/cold
valve that was fitted above the exhaust manifold area of heater hoses. I've see similar
on I think a Trevi. I also recall not finding a valve, but just a
spigot attached to the heater core. I've since converted my hpe back to manual control,
but you can't do that with a functioning a/c.
As to what you need, I reckon a parts diagram may show what you need.
« Reply #2 on: October 31, 2026, 04:28:10 PM »
I acquired a lot of the parts that Nigel had for the air con system and still have them if they're of any use for spares! The part that was used on my car is the main heater box and evaporator as they're different to the non aircon car.
  • Country: au
« Reply #3 on: November 01, 2026, 01:09:55 AM »
Thanks for the replies, I'm in Australia so shiping parts is expensive.
In the meantime I've found some Scorpion/MonteCarlo Info which is close enough for me to do a logic check on the pipes and actuators
It seems as if the ' hot/cold blend' flap is controlled by both vacuum actuators and a bowden cable, but there are no actuators on my car and don't seen to have had them
That's OK though, seems a bit of italian overcomplication to have both.
Next bother will be if the vacuum switches leak and don't function. I might be back to a manual system as per Mk1 cars. I have a control panel to do this and the cables from another car so It's just then a matter of a separate electrical aircon switch. As I'm thinking now, it seems like the most effective path forward, Three sliders, same fan switch and an aircon on/off. just got to work out how to actuate the heater tap for best aircon in the hot weather
Cheers for now. I'm encouraged to find that there are still many active enthusiasts (....or other descriptor) for the dwindling number of Lancia Beta
Dave Foster
2 x Beta Coupe 2l,
Previously in UK
1.3 Saloon 1979
1.6 Saloon 1977
Offline JASPER_40
  • Country: au
« Reply #4 on: November 01, 2026, 01:45:02 AM »
Hi Dave,
I too have had many issues with the vac controls for the A/C resulting from the appauling bodges by previous owners. I invested in a smoke machine for detecting vacuum leaks across all the cars systems and it has paid me back several times. I have found a few split or disconnected vac lines and also a crack in the A/C vacuum reservoir / accumulator which had been glued on by a prev owner.
I never managed to find any diagrams for the A/C controls but with the aid of my my smoke machine, I was able to work everything out and test the integity of everything.....including the actuators.
Where abouts in Australia are you ?
Cheers,
Steve
P.S. My smoke machine also helped me find a vacuum pipe from the carb that a Prev owner had forced a ball bearing well into the pipe to block it off....words cannot describe !!
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #5 on: November 01, 2026, 01:10:24 PM »
Dave,
I found this in a parts list,
Not fully clear but may help.
Page 206 of  https://drive.google.com/file/d/1coZrQTVdG8zKlWaKOxQS82VyTpeS2Snh/view?pli=1
« Last Edit: November 01, 2026, 01:14:17 PM by Nigel »
« Reply #6 on: November 01, 2026, 03:04:21 PM »
I have more information if needed, this is from a North American tech book but I'm assuming this will be much the same
« Last Edit: November 01, 2026, 03:08:59 PM by rossocorsa »
Offline neromoto
  • Country: jp
« Reply #7 on: November 02, 2026, 03:54:53 AM »
I think the Gamma and Beta systems are probably similar, so the Gamma manual should be a useful reference.
My Beta is an early model, so it doesn’t have an air system.
Masataka
Thema 8.32 S2 1990
Gamma Berlina S1 1978
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
Offline JASPER_40
  • Country: au
« Reply #8 on: November 03, 2026, 02:06:43 AM »
Wow...just fantastic Guys
These are the diagrams I always wanted. They tell me so much.
Also helps explain what the mysterious "fast idle" switch / valve is for.
Cheers,
Steve
« Last Edit: November 03, 2026, 06:47:56 AM by JASPER_40 »
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #9 on: November 03, 2026, 01:24:26 PM »
I will wrap them up into a single document and put it in the downloads section.
« Reply #10 on: November 03, 2026, 08:51:46 PM »
The guy who owned my car before I purchased it, bought a used AC system from the Lancia spares guy in SA, he supplied these photo's to him
https://drive.google.com/drive/folders/19uAiTctweMiVFB1JXeoMtal4Zbi1PUdp?usp=sharing
  • Country: au
« Reply #11 on: November 03, 2026, 11:10:30 PM »
Thanks to all for populating the thread, seems like it's not just me with vacuum control problems.
The photo's and diagrams are 'gold' as they say down here ;D ;D
I can move forward with some confidence now, I don't have to deduce what pipe goes where.
The idea about buying a smoke tester is a good one.
On a separate note, I just bought a 1800W induction heater from AliExpress. It heated a 15 mm bar to dull red in about 30 seconds and I was able to extract a broken bolt with no bother. It only works on ferrous material but then that what we mostly have issues with.
Cheers to all, Its made my day  (y)
Dave Foster
2 x Beta Coupe 2l,
Previously in UK
1.3 Saloon 1979
1.6 Saloon 1977
Offline neromoto
  • Country: jp
« Reply #12 on: November 04, 2026, 02:15:32 AM »
Shall I upload a PDF file with slightly better image quality?
Masataka
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
« Reply #13 on: November 04, 2026, 04:39:18 PM »
If you can that would be great.
« Reply #14 on: November 04, 2026, 10:10:49 PM »
I have more information, although it's mostly in Italian, thank goodness for Google lens!, I'll photograph it when I get chance.
Offline neromoto
  • Country: jp
« Reply #15 on: November 06, 2026, 02:20:44 AM »
I have uploaded a PDF file
Masataka
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
« Reply #16 on: November 06, 2026, 04:50:13 PM »
Hi Masataka
Where did you upload it to?
Offline neromoto
  • Country: jp
« Reply #17 on: November 08, 2026, 11:31:21 AM »
Hi Masataka
I have logged in and uploaded it to the Technical Data section of Downroads.
As it is marked ‘Download Not Approved’, I believe it requires the administrator’s approval.
Masataka
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
« Reply #18 on: November 08, 2026, 12:42:32 PM »
Ok, my fault, to stop any rogue uploads, they need to be approved, but I need to look at the bottom of the section for the needs approving line.....
All done now.
Thanks again for doing that.
