Author Topic: modified suspension  (Read 9092 times)
modified suspension
« on: February 19, 2010, 12:32:28 PM »
well, I've tried anyway (fitting for Gamma but would equally suit  Beta)
units came from a subaru WRX STI (had to lay out £25.00 for a s/hand set)
« Last Edit: February 19, 2010, 12:34:34 PM by thecolonel »
Offline hongkongphooey
Re: modified suspension
« Reply #1 on: February 19, 2010, 05:42:10 PM »
That looks fairly close to the beta rears.
Oh hang on.....you've added the bottom lancia fittings to the scooby units haven't you?
« Last Edit: February 19, 2010, 05:44:18 PM by hongkongphooey »
« Reply #2 on: February 19, 2010, 08:16:27 PM »
Yes, seemed the easiest/cheapest way to get what I wanted, they'll be seam welded before use.
« Reply #3 on: February 20, 2010, 11:55:10 AM »
Great work. Did you just use guesswork for the sizing of the scoob units or were they just at the right price? 25 quid is seriously cheap!!
« Reply #4 on: February 20, 2010, 01:27:33 PM »
I sort of reasoned that as the Subaru used a similar engine and was a similar weight
that the units would be close enough to the Gamma, then I decided that at  £25.00
there was no great loss in  "aving a go"  I knew the s/hand units had blown inserts
but still £25.00 for Cusco adjustable coilovers well........ ;D
« Reply #5 on: March 16, 2010, 05:44:05 PM »
well, suspension now installed
cusco/gamma struts, golf front inserts, cavalier rear inserts (actually cavalier fronts fitted to gamma rear)
« Reply #6 on: March 16, 2010, 05:44:40 PM »
and now :-
« Reply #7 on: April 06, 2010, 06:24:21 PM »
Well this is how it looks now :
Offline spud
« Reply #8 on: April 07, 2010, 11:41:07 PM »
Clever stuff... looks fantastic.
Andrew.
Montecarlo S2 Spyder
HPE VX
Y10 GTi.e. x2
Offline LanciaDave
« Reply #9 on: August 06, 2010, 06:01:14 PM »
Yes. That looks very nice! Well done!
Got an earlier side profile pic to compare?
Thanks,
Dave
Oregon, USA
Dave
Wilds of the Pacific NW, USA
77 HPE 1.8L manual steering
77 Sedan 2L FI
84 HPE Vx
« Reply #10 on: August 06, 2010, 08:00:56 PM »
just after paint -
