Author Topic: Pick up points in Marelli Distributor  (Read 7712 times)
Offline cheeky monkey
« on: June 02, 2010, 02:51:27 PM »
I was investigating a fuel starvation issue (i think i have blocked carb jets that a lot of people have mentioned on the forum) and thought id check a few other bits like the dizzy cap whilst i was down there. I couldnt believe the state of the pick up wires leading into the distributor.. chewed up, exposed and one even broken.. so got no idea how ive been starting.!. Anyone know where i can get a replacement pick up in the UK,  and is this a common fault.?.. I guess the whole lot starts rubbing together against the cap over the years
cheers
1979 beta coupe 1300
Re: Pick up points in Marelli Distributor
« Reply #1 on: June 03, 2010, 08:02:50 AM »
Wouldn't it be easier to make some wires up with crimped spade terminals? Most motoring shops sell wire and terminals, mainly for the big car hi-fi market. You just need a crimping tool then, again fairly cheap and I've used mine many times over the years.
« Reply #2 on: June 03, 2010, 10:04:48 PM »
Hi Neil
sorry, probably being thick here.. But terminals to fit into where?. the section above the magnet that the wires go into doesnt allow any movement or opening to do that.
cheers
G
thecolonel
« Reply #3 on: June 03, 2010, 10:46:56 PM »
I would contact the local Bosch agent, pick up leads can be common to a lot of engines.
making your own can be problematical due to original lead resistance.
Geoff
Offline monte
« Reply #4 on: June 03, 2010, 11:17:28 PM »
Try monte hospital ,its probably the same as used on the series 2 montes , they normally have them in stock
1984 Beta Coupe VX
1985 Beta Coupe IE
1980 Montecarlo Spyder
1989 Integrale HF 16V
1989 Thema 2000IE
1991 Thema 2000IE
« Reply #5 on: June 04, 2010, 10:11:32 AM »
cheers guys,
the monte one does look the same. i will try them.
G
« Reply #6 on: June 04, 2010, 06:11:09 PM »
Sorry, was thinking of the wire outside the dizzy cap, I can see now that you mean inside.
« Reply #7 on: June 13, 2010, 12:49:18 AM »
new part from monte hospital fitted and looking fine. just waiting 4 the weber dat 32 gasket kit to arrive & then when carb been cleaned out and put back together hoping it will fire up 1st time.
