Author Topic: Inlet & Outlet pipes  (Read 14321 times)
Offline cheeky monkey
« on: June 19, 2010, 05:09:50 PM »
I thought id replace the fuel hoses for the inlet and outlet to to the carb (weber 32 DAT) as they were looking poor and evidence of a little fuel at the top where it joins the carb. Having put new hoses in its got worse, so i tried a lower bore size & different type of clips i still get petrol coming from at least the inlet but its hard to tell. putting the original pipes back on the prob is worse than it was originally. There doesnt seem to be any damage to the pipes coming out the carb themselves - or is it possible to get a hairline crack in these do you know.?
Ive used a mirror to check around the area and its not coming from any gasket - they were changed recently and look fine.
any ideas appreciated
1979 beta coupe 1300
Re: Inlet & Outlet pipes
« Reply #1 on: June 21, 2010, 11:28:21 AM »
I test pipes by removing them and then blanking off one end and connect the other end to my compressor, then drop the pipe into a bucket of water and fire air through the pipe - leaks should be obvious.
Always use the same bore puipes if you can when replacing.
If the pipes are OK and I suspect the new ones are then I'd be looking at maybe checking/replacing the mechanical fuel pump or check the fuel tank to ensure that its not blocked the main fuel feed.
« Reply #2 on: June 22, 2010, 08:08:35 PM »
thanks Matt
the pipes seem fine and the fuel pumps been changed.. Its almost as if there is too much fuel being pumped through rather than anything being blocked.
« Reply #3 on: June 23, 2010, 06:15:33 PM »
Cheeky
Any chance the float level has been disturbed in the changes? Also the brass pipes press into the carb body I have seen them loose in the past. If this is the case remove it clean it and refit with permanent stud lock.
« Reply #4 on: June 24, 2010, 10:09:52 AM »
Righto Eric.. will have a look at that too.
thanks
« Reply #5 on: July 09, 2010, 08:03:29 PM »
It was the inlet pipe causing the leak.  Once refitted, although the idle was ok I couldnt get the ignition timing right, so Southern Carburettors who are very close to where i live sorted that out.  They have a similar set up to Northampton Motorsports who i think some of you know, with a rolling road etc.  http://www.southerncarbs.co.uk/  I would recommend them.
« Reply #6 on: April 20, 2026, 09:35:12 PM »
Hi all (and original reply to the post Eric) do you stand by this fix?  I have this problem.  I have found you can buy a tap and fitting to replace but also read about gluing it back in.  Any thoughts on what to use?
https://shop.citroenclassics.co.uk/weber-carburettor-inlet-fitting---screw-in-3629-p.asp
« Reply #7 on: April 21, 2026, 09:29:17 PM »
Mark,
I would use that threaded fitting. Much better than
gluing the pipe in. You're almost guaranteed a
permanent fix.
While you're there, do both.
( If not using the return line, there's a fix on my rolling resto page.)
« Reply #8 on: April 21, 2026, 10:15:55 PM »
I am going to whip it off tomorrow.  Thanks Nigel
Just finished front bushes today and taken the cam end caps off.  I have a ARB question, I will search first and post in Suspension if needs be.
« Reply #9 on: April 27, 2026, 12:24:11 AM »
so I tried and tried to get the fuel fitting out and failed.  What I did notice was that it had been pushed in, if you pulled it out, it was very rigid and firm.  So in the end I used a Loctite down the side of the tube, pulled it into place, and used the activator.  I then roughed up the edges of the pipe and used JB Weld.  So far so good.  If it fails again I will have to cut it off and lever out the stuck section
« Reply #10 on: April 30, 2026, 04:33:45 PM »
so far so good :-)
Offline Betared
« Reply #11 on: September 18, 2026, 11:43:32 AM »
I have a similar problem on a carb. I want to overhaul as a spare in that the return pipe has been broken flush with the carb. top. I have managed to carefully drill out the remaining stub and am left with a 6.5mm  diameter hole.There is enough metal to drill out to 9mm dia and use the fitting as described but what I have noticed is the original pipes internal diameter has a restriction in it, I have managed to get a 1mm drill in it.Presumably this has been done to restrict the fuel flow from the float chamber? Has the above modification been tried successfully?
« Reply #12 on: September 18, 2026, 04:54:36 PM »
I didnt know that.  Luckily my fix seems to be holding.
« Reply #13 on: September 18, 2026, 10:24:49 PM »
Assuming you wish to use the return function, I would drill out to 6.8mm and tap an M8
thread.
Then ask a local machine shop to make up a brass tube threaded insert. A simple job.
Fit the insert with suitable locker/sealant.
I didn't know about the 1mm inside diameter, but that could be included in the design.
« Reply #14 on: September 19, 2026, 10:42:32 AM »
Please check if the 1mm restrictor is factory or DIY owner attempt to fix a fueling issue actually else where like pump tank filter or carb intake mesh screen!
Offline Betared
« Reply #15 on: September 21, 2026, 07:16:34 PM »
Eric, I have dug out my copy of the Haynes automotive carburettor manual and the sectioned drawings for the DAT and DATR carbs. show a reduced bore on the outlet pipe.If the drawings are to scale then the reduced bore is some 18% of the connection length.I have sourced a connection on e-bay with a 8mm threaded end ( I have taps that size) and a 5mm bore.Once I've hopefully overhauled the carb. I'll try it on the car and see if there are any fueling problems.
« Reply #16 on: September 22, 2026, 02:09:52 PM »
i was thinking the same, try it and see if there is a problem
« Reply #17 on: September 25, 2026, 01:05:16 AM »
Umm no its not as of a couple days ago.  I needed a quick fix so I have tried JB Weld Tank Weld this time.  A Google it seems JB Weld doesnt like Ethonol.  Why I couldnt find that when I did it the first time?
When I get back from Betameeta weekend I will look at doing this properly.  I have found this for the Inlet, but for the return nothing as of yet
Picture att is the recent go as described above, fingers crossed it lasts the weekend.
Offline Betared
« Reply #18 on: September 26, 2026, 10:43:27 PM »
This is where I got my outlet connector. Fortunately I have taps to cut the thread, but they are readily available on ebay.
www.ebay.co.uk/itm/285032195365?var=587032564210
« Reply #19 on: September 27, 2026, 11:43:37 PM »
Thank you.  Did you do both?  Can you post a picture?
350 miles this weekend on the fix and still looking okay.  I will now sort it out
