Author Topic: Timing marks on an i.e engine?  (Read 5468 times)
Offline Spyder79
  • Lancia Beta Spyder 1979
« on: July 07, 2010, 06:55:36 PM »
Does anyone know where the timing marks are on a 2000 i.e engine?
My Spyder engine has an i.e engine in but i cannot see the marks for tdc etc anywhere.
Tried a timing light and nothing shows up.
any ideas?
Re: Timing marks on an i.e engine?
« Reply #1 on: July 07, 2010, 10:50:51 PM »
Flywheel mark can be seen after removing the little plastic cover on the bellhousing.
Cam wheel pointers/marks are on the metal plate that the yellow belt cover is attached
to, these align with small holes in the pulleys.
hope that makes sense.
« Reply #2 on: July 09, 2010, 08:51:33 AM »
I think there are some marks on the bottom 'point' of the yellow cover as well.
Offline Thotos
  • Theo Kyriacou
    • Lancia Gamma Consortium
« Reply #3 on: July 09, 2010, 12:44:51 PM »
For my Trevi there's a couple of small access panels in the offside wheel arch liner and the crankshaft marks can be seen though them. But I found it easier to remove the offside front wheel and complete front section of wheel arch liner to set the ignition timing. You need a strobe light with fairly long leads!
Theo Kyriacou
