Author Topic: Mark Wast HPE  (Read 31352 times)
markwast
Mark Wast HPE
« on: July 16, 2010, 09:39:15 PM »
Thought it about time I posted something on here about my HPE.
It was orginally a 1600, hence no sunroof  :), a previous owner converted to a 2000.
I ran it last year with twin 45s until late into the year, the clutch release bearing was on its way out.
Over the winter, it finally decided to fail, engine out job to replace.
So since then I have slowly been working on various little projects, ok some rather large in an attempt to get it on the road again this summer. At the moment the engine is out to get the bay looking a little tidier. A replacement engine assembly is waiting to go in.
As I complete various stages over the coming weeks, I will reveal things as I get them fitted.
« Last Edit: July 25, 2010, 11:28:42 AM by Mark Wastnidge »
markwast
Re: Mark Wast HPE
« Reply #1 on: July 25, 2010, 07:50:45 AM »
What a week, or it seems like it.
Engine bay nice, clean and tidy. On inspection of the steering rack, the gaiter needed replacing, so i decided to rebuild to pop in a coupe rack. It needed cleaning, new gaiter and bush.
Replaced the master cylinder, fitted new brake pipes, got the wiring back in.
In between other jobs, like fixing a rattle in the drivers door, i got the wire brush out and started to clean up the d/s sill. Wish I hadnt now, I ended up having to replace the rear section of the sil. Repair inner and outer sections.  I tried for the first time Wayside copper weld through primer. http://www.waysideadhesives.com i must say it works far better than the zinc product i used before.
Hopefully today the engine will be back in, yesterday I replaced the water pump as there was some play in the old one eventhough it only had done about a 1000 miles or so.
Coming jobs this week, collect and fit recored VX rad, fit oil coller on it. Hopefully my new middle exhaust section will be ready too.
I will prob end up doing the other rear sill too.
Will get the car's ass in the air and sort that out too. Clean and sort out rear brakes. New pipes all round.
Ill let you know how i get on.
markwast
Re: Mark Wast HPE
« Reply #2 on: July 25, 2010, 11:29:54 AM »
Engine out B4
markwast
Re: Mark Wast HPE
« Reply #3 on: July 25, 2010, 11:33:08 AM »
Engine bay after
markwast
Re: Mark Wast HPE
« Reply #4 on: July 25, 2010, 11:35:07 AM »
As for the sill, before and after ish........
markwast
Re: Mark Wast HPE
« Reply #5 on: August 11, 2010, 12:37:55 AM »
The latest....
I did the sill the other side, needed doing but ended up being more difficult as there was about 4mm of filler iver the top plus a little spontaneous combustion, panic panic.
With the engine back in situ, all the little bits and bobs were added like carbs etc. With the starter on, we decided to see if it would turn over, well the starter clicked like made, we checked all the wiring was in right, yep no cock ups there, changed the starter not once, twice but three times, still nothing. It turned out the main thick wire from the starter to the battery was shot, changed it and over she turned.
Got the VX rad back from being recorded, god that broke my wallet, 160 quid later, fitted an oil cooler and slimline fan with a new fan switch, on at 85 degrees off at 80 if my memory is right.
markwast
Re: Mark Wast HPE
« Reply #6 on: August 11, 2010, 12:46:54 AM »
And the brakes.................................
With help from Marcus aka lanciamad, new copper nickel brake pipes were fitted, a few little adjustments made, rear discs cleaned up as virtually new, proper fitting EDC pads and handbrake cable fitted.
Front brakes fitted, but a few little adjustments left to do over the next few days, which Im sure might be of interest to some people.
Can you spot a few other little mods in the background?
markwast
Re: Mark Wast HPE
« Reply #7 on: August 11, 2010, 12:56:12 AM »
Undecided which of the three gear shift options i have to go for, prob not the standard one, i have a spare prototype of the very short shift but most proberly go for the medium shift so i can test that, measure the throw etc. I fitted new bushes, and short rod along with brass bushes in the pivot mounted on the subframe, Am thinking of getting a batch made along the the pivot rod itself especially as the one in my berlina is well worn, gearstick moves side to side in gear as if it was in neutral. Need to find another engineering company as my local one a tad busy right now. Suggestions on a postard please .......
markwast
Re: Mark Wast HPE
« Reply #8 on: August 11, 2010, 01:01:48 AM »
Pic of linkage in place, I could only find two decent ball studs and had to fit the best of the rest , and would you believe it, my delivery of new ones arrived friday, will be on the site next week.
markwast
Re: Mark Wast HPE
« Reply #9 on: August 11, 2010, 01:02:52 AM »
Engine bay pic......
Re: Mark Wast HPE
« Reply #10 on: August 12, 2010, 09:53:02 AM »
Great to see parts of a Beta looking 'brand new'!
markwast
Re: Mark Wast HPE
« Reply #11 on: August 12, 2010, 10:15:44 PM »
Thanks Neil, lots of time taken and over the winter it will be resprayed to match the parts.
markwast
Re: Mark Wast HPE
« Reply #12 on: August 12, 2010, 10:16:48 PM »
Fitted the exhaust today, car will be fired up tomorrow if i get a chance.  If any interest I will offer this centre section on the parts website.
Offline redvxcoupe
Re: Mark Wast HPE
« Reply #13 on: August 13, 2010, 01:15:42 PM »
Great looking exhaust ;D
Can you please explain about the front brakes.....
Looking forward seeing you and the car next year
1983 VX Coupe
1984 VX Coupe
1994 Dedra HF Turbo Hörmann
2002 Thesis Turbosoft
Offline Thotos
  • Theo Kyriacou
    • Lancia Gamma Consortium
Re: Mark Wast HPE
« Reply #14 on: August 13, 2010, 01:28:19 PM »
So is that a single silencer exhaust system? Looks lovely...  :-*
Theo Kyriacou
Re: Mark Wast HPE
« Reply #15 on: August 13, 2010, 03:57:25 PM »
A quality job you deserve the huge grin you will have when driving it! As you might expect I am very interested in how you find the front brakes. Did you bypass the rear load balance set up as I suggested?
PS still no progress on whether the VX rears will work.
markwast
Re: Mark Wast HPE
« Reply #16 on: August 14, 2010, 03:14:48 PM »
Thanks, well the brakes are HiSpec 4 pot calipers with 284mm HF Integrale vented discs. I had to get mounting brackets, spacers made up and Goodridge braided hoses. Yet to see how they work yet.
markwast
Re: Mark Wast HPE
« Reply #17 on: August 14, 2010, 03:16:05 PM »
Yet to here what it sounds like, loud i expect.
markwast
Re: Mark Wast HPE
« Reply #18 on: August 14, 2010, 03:18:16 PM »
Thanks Eric, yes i by passed the compensater infact took it all out.
Re: Mark Wast HPE
« Reply #19 on: August 15, 2010, 12:57:10 AM »
Do you have a brake bias fitted ? or are the rear brakes working as hard as the fronts ?
(always thought that rears only partially worked unless you were carry a lot of rear weight)
Geoff
