Author Topic: Fan over ride switch  (Read 10603 times)
markwast
« on: August 11, 2010, 12:19:24 AM »
Has any one a wiring diagram to fir a over ride switch for the cooling fan, Im crap at electrics so like to be safe rather than sorry.
Re: Fan over ride switch
« Reply #1 on: August 11, 2010, 01:03:32 PM »
If it's a standard system then the simplest way is to graft a new wire onto the fan earth
and run that to a switch, the other terminal from the switch goes to earth.
Offline redvxcoupe
« Reply #2 on: August 14, 2010, 12:05:49 AM »
Think lanciamad has done this in his hpe....
You should def use a relay, if not, too much current is going through the switch
1983 VX Coupe
1984 VX Coupe
1994 Dedra HF Turbo Hörmann
2002 Thesis Turbosoft
« Reply #3 on: August 14, 2010, 12:50:50 PM »
Agreed, relay is always the best option.
Get a standard 4 pin relay
30 to earth
87 to fan earth wire
85 to + 12v
86 to switch
switch to earth
Geoff
« Reply #4 on: August 15, 2010, 01:25:50 PM »
Relay is deffinately the way to go, if you buy one in packaging they more than likely tell you which wires connect to the relay anyway. Just to clarify, mine's not currently an over-ride switch, but an additional switch for the secondary fan i've got fitted.
Offline TreviDash
« Reply #5 on: August 16, 2010, 01:09:01 PM »
If it helps, I could compile and publish Andy Batchelor's redesigned electrics trialled and fitted to his Betas.  This rerouted the high-current circuits for lighting (fan too with dash override) away from the main fusebox, with an array of relays in a secondary fusebox in the position where Lancia fitted its own secondary fuxebox in the Automatic Betas.
'84 Alfa 33 Gold Cloverleaf
'92 Daimler Six
Offline redvxcoupe
« Reply #6 on: August 16, 2010, 01:43:09 PM »
Yesss please   ;D
1983 VX Coupe
1984 VX Coupe
« Reply #7 on: August 21, 2010, 08:18:10 AM »
Contact Darren Cooksey (Montecarlo Consortium Member Sec) before Gaydon and get him to bring the comprehensive wiring diagram he has for this including a light to tell you the fans are operating.
