Author Topic: Electronic Ignition?  (Read 5884 times)
« on: August 29, 2010, 05:48:59 PM »
It's just about time to change the points on my 1300. I'm thinking of fitting an Aldon 'in distributor' type of electronic ignition. Has anyone else done this? Any comments/problems?
Re: Electronic Ignition?
« Reply #1 on: August 29, 2010, 07:16:47 PM »
« Reply #2 on: August 29, 2010, 10:21:59 PM »
Find someone breaking a later car and take the electronic ignition module, distributor, coil and ballast resistor from that. It's pretty simple to splice into the wiring. I've just completed this with my 2000
You'd just need to make sure the advance curves aren't too different for the 1300.
Stuart
Offline hf_dave
« Reply #3 on: August 30, 2010, 09:48:52 PM »
I saved an electronic unit from a later beta 1600 Will this work on the 2000 :-\
