Author Topic: Brake Master Cylinder  (Read 4633 times)
Offline the_matrix_master
« on: February 21, 2011, 12:25:41 PM »
The brakes on my Spyder have gone a bit "Spongy" !
1st press of the brake pedal and there is a fair amount of travel 2nd imeadiate press of the brake pedal and the brakes are back at their best.
Since there is no discernable drop in the brake fluid and I cannot find any leaks at the pipes or nipples I an assuming the master cylinder is on its way out ?
As a new cylinder is about £85 and repair kit is about £15. I thought I would go down the repair kit route.
Does anyone know if the Beta Spyder repair kit is comparable with a later day car ? The fiat X19 cylinder and repair kit is compatable with the Montecarlo but not the Beta Spyder.
Can I buy this kit over the counter at a local motor factor as I can see the kits on the web for around £15 in the UK for the Beta Spyder but they want £5 P&P for what is basically rubbers that you could send in an envelope at the cost of a 1st class stamp.
I have found a kit in the States for $12 but they wanted an unbelievalble $35 to ship it LOL
Re: Brake Master Cylinder
« Reply #1 on: February 21, 2011, 08:12:35 PM »
 original part number was 82293524 or 82369266 it is common to Gamma and possibly (not 100% sure) to Fiat ritmo/strada 130tc
have you tried a really thorough bleed using an easibleed or similar device and renewed your fluid?
« Last Edit: February 21, 2011, 08:55:01 PM by rossocorsa »
Offline JoeBeta
« Reply #2 on: February 21, 2011, 09:23:13 PM »
Would agree, sounds like you just have some air in the system.
It can sometimes take several attempts at bleeding to get all the air out.
I would have thought if it was the master cylinder, the peddle would continually drop with constant pressure???
« Reply #3 on: February 21, 2011, 10:37:35 PM »
Thanks guys.I never really considered that the problem may be down to air in the system or fluid past its best (Doh!).
It seems a sensible place to start.I will renew the fluid and bleed as see where I get.
« Reply #4 on: February 22, 2011, 05:06:11 PM »
Over time the brake fluid absorbs water/moisture and becomes less effective.
Start with furthest caliper from master cylinder and flush through until new fluid comes through the bleed nipple.
If it's still spongy then M/C might need to be replaced. But do the fluid first as people have suggested.
Good luck!
« Last Edit: February 23, 2011, 07:52:48 AM by MattNoVAT »
