Author Topic: beta windscreen  (Read 5906 times)
tonylanciabeta
beta windscreen
« on: December 07, 2008, 08:41:10 PM »
From: alfasudtwinengine  (Original Message)   Sent: 15/03/2008 01:31
Hi could any one help i am after a clear front windscreen and rubber seal for a beta coupe please email mickcovill@aol.com
Omicron do beta windscreen rubbers but they are not cheap, i got quoted
around 100 pounds. I used Master Bond in the end which is available here
http://cgi.ebay.co.uk/WINDSCREEN-GLASS-SEALANT-BONDING-ADHESIVE-GLUE-CAR_W0QQitemZ320159250443QQihZ011QQcategoryZ30923QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
not sure where you would go about the front windscreen, try ebay as
there are some people selling spares from their betas.
Hope that helped a little
Luke
Hi, my project has reluctantly turned into a 'break for parts' project!  Have a good windscreen still fitted to the car... if I can work out how to remove it in one piece I will post again.  I am in South Somerest...any good?  Have loads of other coupe parts to shift.
Paul
Hi Mick
have you tried
http://www.heatedwindscreen.com/acatalog/Beta.html
Hi thanks luke i was trying to get a second hand one i will prob end up bonding it in thanks .
hi paul thanks but you are a bit to far away as i am in lancashire thanks again mick.
Thanks tony they can supply one.
