i need to set up the ignition timing on my beta,2000 carb model, bosch electronic ignition.
the haynes manual shows a different crank pulley to mine.
the manual shows timing marks on the yellow plastic cover, mine has none on the cover.
mine has a pointer near the crank pulley and 3 marks on the pulley. one mark is on the back face of the pulley and 2 on the front face.
how do i set the timing?
i guess i need to get it roughly correct and then start the engine and fine tune it with a strobe. i just need to know which is the correct mark.
