Author Topic: Alternator top mounting point  (Read 3822 times)
Offline cheeky monkey
« on: December 12, 2011, 12:34:53 PM »
The bush on the top mounting bracket of the alternator needs replaced. Does anyone know of replacement source or suitable alternative?.
thanks
1979 beta coupe 1300
Re: Alternator top mounting point
« Reply #1 on: December 12, 2011, 05:43:59 PM »
Go looking for Rubber Grommets you can usually either just fit a grommet and push the metal sleeve in or sometimes put the metal sleeve in a hose off cut and push it in. This assumes you still have the metal cupped washers on both sides.
« Reply #2 on: December 13, 2011, 02:23:35 PM »
Got it. See what you mean. Ive got the metal washers so will give that a go
thanks
