Author Topic: brake calipers  (Read 7602 times)
Offline raz1966
brake calipers
« on: March 04, 2012, 09:43:21 PM »
does any one know if fiat x1-9  calipers are the same as beta coupe? i need seals front and rear and x1-9 seals are cheap on ebay
Offline raz1966
Re: brake calipers
« Reply #1 on: March 04, 2012, 09:53:33 PM »
i managed to kit the cotter pins for the wedges but can find the springs that go on the brake pads, any one know where i can get some?
Re: brake calipers
« Reply #2 on: March 04, 2012, 10:44:07 PM »
Are there supposed to be springs on the pads? I don't recall ever seeing any.
Have you got a picture ?
Re: brake calipers
« Reply #3 on: March 05, 2012, 01:08:26 PM »
There are no springs for beta brakes!
Offline targa2000
Re: brake calipers
« Reply #4 on: March 05, 2012, 02:09:22 PM »
Not sure if early models had them but later models were fitted with a brake pad anti-vibration spring.
lanciabetaparts have them, part no BBBK07 for the set, hope this helps.
Offline Thotos
  • Theo Kyriacou
    • Lancia Gamma Consortium
Re: brake calipers
« Reply #5 on: March 05, 2012, 02:12:15 PM »
I am fairly sure they are not. X1/9 callipers are like Fiat 127/128/131/132 which are similar to Beta but not the same.
Montecarlo (Fiat X1/20  ;)) callipers are probably the same as X1/9.
« Last Edit: March 05, 2012, 02:23:13 PM by Thotos »
Theo Kyriacou
Offline Thotos
  • Theo Kyriacou
Re: brake calipers
« Reply #6 on: March 05, 2012, 02:19:33 PM »
There are certainly springs on the (Beta) Trevi pads but normally come as a set with the pads.
http://www.ebay.co.uk/itm/Brake-Pad-Set-Front-Lancia-Beta-Trevi-/180828767024?pt=UK_CarsParts_Vehicles_CarParts_SM
Theo Kyriacou
Re: brake calipers
« Reply #7 on: March 05, 2012, 04:29:24 PM »
often the springy bits come as an optional 'fitting kit'
Re: brake calipers
« Reply #8 on: March 05, 2012, 07:08:05 PM »
OK Now I see them I have seen some pads with them though I don't think my cars have ever had them fitted.
Re: brake calipers
« Reply #9 on: March 05, 2012, 10:29:25 PM »
Ditto !
Offline mtulloch
Re: brake calipers
« Reply #10 on: March 12, 2012, 05:25:43 PM »
I've had them on all 6 of my Betas.
