Author Topic: Door Cards  (Read 7098 times)
Offline Gerhard
Door Cards
« on: March 29, 2012, 09:02:37 AM »
After getting the Beta back from the extended engine rebuilt, and then driving it to see if all is well, I noticed that the driver side door card was loose at the bottom. Took it off, bottom totally rotten away, so now the new project on it is to replace the offending part.
Used the old one as a template to cut a new one, then the project came to a screaming stop. Can not find replacement plastic holding pins (?) that clip into the door frame.
Anyway here's some photo's of the project so far.
Re: Door Cards
« Reply #1 on: March 29, 2012, 10:11:52 AM »
Gerhard,
You mean these?
http://www.ebay.co.uk/itm/Fiat-128-131-Lancia-Gamma-Beta-Delta-fix-clip-interior-/260976476395?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc36900eb
I bought these in advance as I know the originals go brittle or have been damaged prior to me getting the car, plus I bought other trim clips and plastic indicator screws off the same guy so saved on postage.  They were identical to the originals and they are new as opposed to NOS. (New Old Stock)
« Last Edit: March 29, 2012, 10:15:25 AM by MattNoVAT »
Offline Gerhard
Re: Door Cards
« Reply #2 on: March 29, 2012, 10:20:08 AM »
Hello Matt,
Yes that's the one's. But as always being at the bottom end of the world, I will have to see if I can get some local ones.
Thanks,
Gerhard
Re: Door Cards
« Reply #3 on: March 29, 2012, 10:46:05 AM »
Gerhard,
The guy is based in Portugal and ships worldwide, it took no more than 10 days for mine to arrive.
Offline Gerhard
Re: Door Cards
« Reply #4 on: March 29, 2012, 10:50:54 AM »
I saw, he is actually staying in the same town as my brother in law. Let me first see if I can get local, failing that I will order some from him.
Offline cheeky monkey
Re: Door Cards
« Reply #5 on: March 29, 2012, 12:55:08 PM »
i got some samples from bresco.com. One was a good fit so i'll look up the part number tonight.. just so you have another alternative.
graham
1979 beta coupe 1300
thecolonel
Re: Door Cards
« Reply #6 on: March 29, 2012, 01:32:19 PM »
Chap in Portugal is excellent, good quality and relatively
cheap.
Offline Gerhard
Re: Door Cards
« Reply #7 on: March 30, 2012, 07:34:25 AM »
Thank You Sir. I requested my brother in law to pick some up for me, as he is also living in the same town. (Save some cost)
Offline Gerhard
Re: Door Cards
« Reply #8 on: March 31, 2012, 09:30:13 AM »
I found some clips here in Durban. R60.00 for 10. Attached some more photo's of the card. I decided to seal the Masonite board, hopefully will then last longer.
Re: Door Cards
« Reply #9 on: October 07, 2012, 11:28:05 PM »
graham
Can you let me know the part number?
