Author Topic: gear selection problem  (Read 4872 times)
Offline credders
« on: June 04, 2012, 12:57:54 PM »
ive not used my beta for a while but had to move it out the garage. when i selected 1st it didnt seem to go in far enough and jumped out, if i hold it in it is alright and dosent jump out when on the move. i know these are prone to linkage bush problems i havent had the chance to take it for a blast down the road yet. ive had a look in the manuel about this 15degree angle of gearstick. myquestion is, should i try to adjust linkage or just get new bushes providing the box is ok?
Re: gear selection problem
« Reply #1 on: June 05, 2012, 09:27:57 AM »
I'd give it a good test run first. Jumping out or failing to select are usually box problems. Sloppy or difficult selection are normally the sign of a shot linkage only.
How long has the car stood for? The oil might be past it's best and stuck to the bottom of the box making things worse?
« Last Edit: June 05, 2012, 09:30:37 AM by Neil-yaj396 »
Offline credders
« Reply #2 on: June 05, 2012, 09:49:13 AM »
its been stood for a year now, it got better the warmer it got so you could be right about the oil! handbrake is sticking so im on with sorting that now so i can get MOT then have a better check.
Offline credders
« Reply #3 on: June 30, 2012, 04:49:27 PM »
a bit of use seems to of cured the jumping out of gear problem, ive put it down to a linkage problem due to it been stood :D
« Reply #4 on: July 01, 2012, 08:35:54 AM »
Did you change the gearbox oil? If not I'd definitely do so.
