Just (at last) managed to remove the rear bleeds without the usual 'snap'. What a sod of a job!! Plenty of Plusgas, gentle heat, a bit of patience, decent 8mm socket and voila! I can now change the seals, new pads and then on with the bleed etc! Even the HB cable is in good order still - a bit of luck for a change
