Author Topic: Oil temperature sensor  (Read 8080 times)
Offline lukasdeopalenica
« on: December 16, 2012, 07:40:30 PM »
Can anybody help me with that? I have found that similar, if not the same, sensors are used in lancia dedra, thema, alfa 155 etc., but I am not sure if they have the same characteristics.
Subaru Outback 3.0R
Re: Oil temperature sensor
« Reply #1 on: December 16, 2012, 08:51:30 PM »
I is so long since I drove my Beta but I didn't think it had an oil temp gauge and/or sensor? did you mean oil pressure
Offline lanciamad
  • Marcus Robinson
« Reply #2 on: December 16, 2012, 09:29:00 PM »
It has been a while, the gauge is top right of the dash display ;)
2001 - Honda Civic Type R EP3
Re: Re: Oil temperature sensor
« Reply #3 on: December 16, 2012, 09:58:37 PM »
I'll try to check tomorrow many of these sensors are generic to loads of Italian cars
« Reply #4 on: December 17, 2012, 08:03:09 AM »
haven't had much time so proceed with caution I haven't double checked these numbers! 82240626  seems to be the number for s2fl (other series might differ I haven't time to check this morning) alternative numbers may be (please cross reference these yourself to be sure)  7588856 7589337 82357865 but I haven't had time to research properly and I'm afraid I will not have time this week but use this as a starting point for your research. Please post your findings here when you are successful
Alan
« Last Edit: December 17, 2012, 08:09:38 AM by rossocorsa »
« Reply #5 on: December 17, 2012, 08:04:10 AM »
yes over 10 years!!!
« Reply #6 on: December 17, 2012, 10:02:05 PM »
Thanks for the reply,
comparing the numbers it seems as it should be the same sensor as used in newer dohc family equipped cars as dedra, thema, alfa 155 etc. I am guessing the sensor apart of a special sealing should not differ from water temp sensors having 14x1,5 thread and with the NTC characteristics.
My oil temerature gauge goes just a bit when the engine is warmed, but when I short-circuit the wire, the dial goes to the maximum. Hence I suspect the sensor, however at 20C the sensor has resistance about 4kOhm and decreases with the temperature rise. But the lowest resistance is to high, I recon it should be close to zero...
Subaru Outback 3.0R
« Reply #7 on: December 19, 2012, 07:19:32 PM »
Only face lift cars have an oil temperature guage.
« Reply #8 on: December 19, 2012, 10:17:06 PM »
I think you might be mistaken there. AFAIK all coupes & spiders pre F/L with the brown dash had an oil temperature gauge top right. Both mine certainly have had.
« Reply #9 on: December 20, 2012, 05:22:57 PM »
Top right is the hazard warning light on mine. Maybe a cheapo 1300 thing then?
« Reply #10 on: December 20, 2012, 10:15:31 PM »
On S2FL it looks like this (no. 11)
Subaru Outback 3.0R
