Author Topic: Inboard CV joint re-assembly  (Read 3581 times)
Offline glovebeast
« on: December 29, 2012, 04:56:46 PM »
I've removed the in-board CV joint in order to replace both inner and outer boots. There is a washer that goes on the splined shaft before the CV joint; Haynes and the Fiat manuals just describe it as a washer, but mine are dished.
1. is this correct
2. if so, which way should it face?
TIA
Steve
BTW car is a Volumex HPE
Re: Inboard CV joint re-assembly
« Reply #1 on: December 30, 2012, 09:46:01 AM »
The dome should be towards the joint it is just putting some spring load into the assembly to stop it shuttling on the spline.
Offline glovebeast
« Reply #2 on: December 31, 2012, 12:04:43 PM »
Thanks Eric - I'll re-assemble later today
Happy New Year!!
