Have you tried the two main connectors that go into the bottom of the fusebox either side
Check for corrosion and condition.
One is straight from the battery, the other from the alternator.
The connector of one of mine broke when i was out driving and it resulted in me loseing half the electrics.
Also worth removing the fuses, and giving the contacts and fuses a little clean.
