One other question are they handed and is there a front/rear wing version?
They are handed but mounting is simply four self tapping bolts with 8mm hex heads, similar to a lot of Beta trim fasteners, which attach to the inner wing, two in front and two behind the strut.
My '78 doesn't have the mounting holes but there are two easy options for mounting.
Either mark and drill 3mm diameter pilot holes after offering up the liner with the wheel removed, or use self drilling TEK screws which have an 8mm hex head and a large diameter galvinised washer with a rubber face attached and simply run them in while your assistant (Well, you need someone to blame) holds the liner in position.
I suspect that when I remove the liners from the coupe that those square section plastic inserts which are another staple of lancia trim, will be present in factory-made holes but as I don't own a bit that'll drill square holes, I'll be using the TEK screws
There is no evidence of rear arche liners on either my coupe or '79 facelift spider so I assume they never had them.
When I get a chance, I'll get the pics off to you. I have to find my camera first as I live in chaos
