I agree wholeheartedly.
When I recomissioned my spider after it was laid up from 1988 until 2010, I neglected to clean the carb, the result of which was to have the car die on the side of a "b" road in the dark!
the lucky thing was that it happened outside the house of one of the most obliging people I ever met who came out to see what was going on, then set up an airline from a compressor in his shed, provided me with tools and we dismantled the carb and blew the jets out, removed the filter in the actual carb and cleaned years of crud out of it as well.
lLsson learned!
Also, when I fitted a new fuel filter, i fitted it between the steel fuel line and the incoming side of the fuel pump as some pumps have a gauze in them which can clog with dirt and then fail to deliver to the carb.
The filter I used is one with a removable, cleanable bronze element and I clean it after every run.
It's slim, neat, easy to fit and aesthetically pleasing as opposed to one of those transparent plastic yokes hanging suspended between the fuel pump and the carb.
At this stage, very little, if any, dirt shows up in it as the tank seems to have given up all the residual debris.
I should mention that the rubber sections of the feed and return fuel lines all had to be replaced as they systematically went porous as each preceeding one was replaced, including the lines from the tank to the lines at the rear of the car.
It's a low cost, high reward job which not only stops leaks and unnecessary fuel loss, but stops fumes and reduces the risk of fire so I consider the lines and filter, along with new hose clips, twenty quid well spent
