Hi All,
I have recently bought some secondhand Beta Spider seats and have a couple of queries about them (I am reposting this with a pic this time) :
1. Are the rear seat bases on the Spider (2000 F/L model) meant to have one or two locating lugs, or pins - each of mine have just one lug on the bottom of each base, although on one of them it's very weak, barely hanging on, so cannot be used.
2. On the fronts seats how do I replace the front bolt which holds the runner to the actual seat frame - on one of the seats one runner is loose as the bolt has previously been removed and I cannot access it as the runner itself blocks it and there is no access hole at the front of the runner (the rear bolt on the other hand is easily accessible as there is an access hole in the runner). There was advise previously posted stating that the end of the runner had to be removed but I cannot see how this can be done. I have attached a pic which explains things better.
Any help with these queries would be very much appreciated.
Best regards,
Chris
