Would it be possible to thread a piece of fishing line or the likes through and attach a BOLT to it?
You could then pull it up through the hole and track and eecure the track by using a locking washer and a half nut to keep the profile low.
I'm presuming the second hole you refer to would accomodate a bolt.
It would be necessary to use longer than required bolts so you could fit the washer and nut then hold the portion of bolt above the nut with a vise grip while tightening the nut with possibly a swanneck ring spanner.
Having said all that and just retrieving a mental image of the lack of space between the sides of the rail, unless it is the front bolts, it would leave it impossible as the nuts would beed to be spaced up above the level of the runner.
I've done similar in the past with success but I'm sure someone will have a more practical plan.
