The 75w90 in the box is good - but i don't have and have never had the cold gear change problem with any of my Betas.
The 1600 gearbox in a 2000 is a total utter waste of time, actually kills performance.
Just because it "zips" through the gears does not mean it makes your car faster on acceleration.
My old Trevi had such a conversion and it just screamed, the shorter gears made the car a little slower if anything.
My VX also had an IE gearbox - exactly the same thing, if you want to rev the nuts out of your engine and waste fuel do it by all means, just an old wives tale.
If you route the speedo cable behind the fuse box and wiring you wont burn the cable anyway.
They out to show a mod where you make a heat shield to cover the steering rack to stop the boot from burning.
High octane unleaded - shell V-Tech and other premium fuels win over 95ron (green) cheapo unleaded any day.
Cant comment on the springs and brakes mentioned - i think the Beta is low enough!
I have Tarox discs and brakes on the front of both my VX's and i will go with Eric Weston - no real improvement over standard other than the pads last for ages.
I do 3000 miles a year and they are still going after nine years.
