Hi All,
Had the steering rack bush replaced on my coupe (manual TRW rack) about 4 years ago with a repro item. Have just noticed after a long run today the same knocking noise through wheel. Can seem to move rack up/down slightly when grabbing n/s control arm; some movement but less pronounced when doing similar with O/S control arm - Am I on the right lines?
If it is the bush then is failure after just a few years and probably not much more than 7/8 K miles normal?
See that Betaboyz parts now shows a Polyurethane item as alternative? Has anybody any experience of this as an alternative?
Finally, last time had local mechanic/garage that I know change bush as didn't fancy trying to do this job at home without access to lift. Is this straightforward if I get car up on axle stands or is it not worth the faff?
All advice greatly appreciated.
Thanks,
Andrew
