Author Topic: Rear Crossmember  (Read 9380 times)
Offline George-S
Rear Crossmember
« on: December 20, 2016, 12:01:13 PM »
Hello
One of my Rear Crossmembers is bent beyond repair. Despite my best effort I cannot locate a replacement. any suggestions or places I can find a used one ? .. PLEASE help !
Re: Rear Crossmember
« Reply #1 on: December 20, 2016, 12:51:26 PM »
Hi,
Do you mean the tie rods that go between the rear hub and the centre of the car? They do get bent quite often by people trying to jack the car with them.
If so there are two types  - can you post a picture of yours?
Offline George-S
« Reply #2 on: December 20, 2016, 07:49:47 PM »
Photos In the link below https://goo.gl/photos/jt1Fv4u8dNkvYrr49
Thanks for the help !
Offline George-S
« Reply #3 on: December 20, 2016, 07:50:29 PM »
Does Seem very much as if someone had jacked it from it .
« Reply #4 on: December 20, 2016, 09:32:45 PM »
Yep - and then tried to straighten it by the look of it.
That's what I'd call a channel type arm ( it's a U section) the best bet is to find people breaking Betas or selling Beta parts and ask if they have one. You might also look on the overseas sites such as Lancia Cape Town or Midwest Bayless to see if they have one. They are not al that common for exactly the reason you need one.
Push come to shove you can make one with some tube and a couple of rod ends but finding an OE one might be simpler.
« Reply #5 on: December 20, 2016, 10:24:39 PM »
Can't tell for sure from the pics but it looks like you have a pre-facelift series two with all pressed arms ?? If so you'll have the funny eccentric bolt tracking adjustment, I think it should be possible to change to fabricated style arms with simple adjustment you might wish to do this. Not 100% on the compatability but no doubt someone else will know.
Offline betaveloce
  • Country: be
« Reply #6 on: December 21, 2016, 09:05:44 AM »
I think I may have this item New Old Stock. I will check tonight  ;)
Beta Spider 1.6 '80
Beta HPE 2.0 i.e. '82
Offline George-S
« Reply #7 on: December 21, 2016, 09:17:05 PM »
THAT Would be great if you did !
Offline betaveloce
  • Country: be
« Reply #8 on: December 23, 2016, 08:36:21 AM »
I have found it. However, on the label, someone wrote 'HPE',  and here (http://lancia.co.za/article/Beta/Beta+Saloon+1.6+S1/Miscellaneous/2349727.html) it is listed for a saloon...
But I would suspect that it's the same for all models, no? Anyway, the part number is 82349727. They also have it in stock here, but rather expensive: http://www.autoricambi.rollgarage.it/meccanici/58799-asta-originale-fiat-lancia-82349727.html.
Like I said, the one I have is NOS, but I have to mention that the rubber from the bushes is a bit perished.
Let me know if you're interested and then I can try to find out how much postage to the UK would be  ;)
Beta Spider 1.6 '80
« Reply #9 on: December 23, 2016, 08:47:01 AM »
 Think the one for hpe/Berlina has a small fitting for the headlight leveling but otherwise would be the same
Offline betaveloce
  • Country: be
« Reply #10 on: December 24, 2016, 02:08:07 PM »
Of course, that has to be it, didn't think of that  ::)
Beta Spider 1.6 '80
Offline betaveloce
  • Country: be
« Reply #11 on: January 02, 2017, 02:33:18 PM »
shall I just put it back in my shed then...?   :-\
Beta Spider 1.6 '80
