I am moving this at Neil's suggestion- I must admit I didn't spot what the other thread was called, just glad to find some info.
I have just pulled my jumpy regulator out. I think that the issue is the pinion rather than the 'rack'(spring) as the spring looks fine, but it jumps at the same place on each handle revolution.
I have a NOS regulator, BUT, it is a bit kinked and straightening it looks tricky without kinking the split tube.
So, probably a silly question, can you get the the winder apart, so I could perhaps put the new winder on the old mech, pcossibly with a new spring? This suggests it is to change the spring?
[/quote]
