Author Topic: Bonnet parts  (Read 6913 times)
Offline dommorello
Bonnet parts
« on: January 22, 2017, 09:42:30 AM »
Gday, even though we had two cars to pick parts from we could only reuse one of the bonnet spring brackets parts that hold onto the car. See attached photo.
Any ideas where we can find these or if anyone has thoughts on using substitute part?
Re: Bonnet parts
« Reply #1 on: January 22, 2017, 12:58:01 PM »
I may have a spare one rescued from one of the cars I scrapped. I will have a look and see.
Offline dommorello
Re:
« Reply #2 on: January 23, 2017, 07:35:23 PM »
Thanks Peter that would be fantastic. Cheers
Sent from my HTC 2PS6200 using Tapatalk
Offline zagato8182
Re: Bonnet parts
« Reply #3 on: January 24, 2017, 02:10:00 AM »
There are used ones available on Ebay now in good shape.
They are listed as hood latch.
Offline dommorello
Re:
« Reply #4 on: January 24, 2017, 08:17:19 AM »
Really? On eBay? I can't find em. Can you pls send link. Cheers
Re:
« Reply #5 on: January 24, 2017, 09:19:36 AM »
I suspect you are referring to (could be wrong of course, happens a lot according to my better half....)
http://www.ebay.com/itm/Lancia-Beta-Coupe-Zagato-Spider-HPE-Hood-Prop-Latch-/232196815468?hash=item3610023a6c:g:3UIAAOSw8gVX22RK&vxp=mtr
This is the metal loop, not the mounting brackets which I assume you are looking for?
Offline dommorello
Re:
« Reply #6 on: January 24, 2017, 09:34:34 AM »
No from picture you'll see I have the metal loop. We are after a mounting bracket. As per photo missing right hand one but believe they are interchangeable
Re: Bonnet parts
« Reply #7 on: January 24, 2017, 10:32:57 AM »
Ok, interesting. The ones on my car (early S2 pre f/l) are two piece comprising of a metal bracket and plastic bush/bearing for the metal hoop. because the retaining slot is in a slightly different place you cannot change between the two types.
The car I scrapped was also a pre f/l Spyder, but has the same brackets as you are after, so yes have one here in my (now grubby) hand....
Send me your address and will put in the mail for you. You are correct they are the same for both sides, i.e. interchangeable.
Offline dommorello
Re:
« Reply #8 on: January 24, 2017, 10:52:05 AM »
Peter that would be awesome mate, thanks!
My address is Po box 147 Brunswick East Victoria 3057 Australia
Send me your bank details and I'll eft you some cash to cover postage etc
Re: Bonnet parts
« Reply #9 on: January 27, 2017, 10:27:45 AM »
Sent via standard post, so guess it will take a while, but hopefully will be with you reasonably soon!
Offline dommorello
Re:
« Reply #10 on: February 07, 2017, 11:16:08 AM »
Peter, received it today. Thank you!!! Send you me your bank details. Cheers
Re: Bonnet parts
« Reply #11 on: February 07, 2017, 08:34:06 PM »
Not a problem, have it as a present, if you want to spend some money make a donation to the forum, but for me happy to see your amazing car get back together!
