Author Topic: Clutch balance marks  (Read 4042 times)
Offline jreacock
« on: February 25, 2017, 07:36:36 PM »
Hi all. I was going to fit the clutch today, and then join the gearbox back to the engine in an attempt to progress the rebuild. However - the clutch pressure plate doesn't seem to have a balance mark on it - as mentioned in the manual. The flywheel has a clean patch that I assume used to be a painted stripe, and from what I can see, the old plate (which has a yellow line painted on) was around 180 degrees offset from the 'clean' mark on the f/w.
So - there are a few green painted blobs on the new plate, but this isn't something the manual references. Anyone come up against this type of issue before?
Cheers,
Justin.
69 Fulvia 1.6HF S1
71 Works Fulvia 1.6HF
75 Gp4 Stratos HF
81 Beta Spyder 2.0
82 037 Rally stradale
Offline jreacock
Re: Clutch balance marks
« Reply #1 on: February 26, 2017, 09:49:58 PM »
Okay - so I went ahead and fitted this pressure plate today. There were 2 green paint marks, neither of which seemed to line up very well at 180 away from my f/w white paint mark, so I have split the difference. I think that this is the best I can do.
« Last Edit: February 27, 2017, 01:15:29 PM by jreacock »
69 Fulvia 1.6HF S1
75 Gp4 Stratos HF
81 Beta Spyder 2.0
