On Spiders the outer sills are bigger than on other models to give extra strength. As they are a little wider there's a slight step under from the bottom of the door out to the edge of the sill covered by a the rubber strip in it's stainless holder. The same step can be seen in the bottom section of the front wing.
At some point in production the 'step' got slightly smaller. I'd guess this might have been during the S1 to S2 change when it acquired the longitudinal roof bars and therefore may have needed less floorpan strength. It way well have also coincided with the change in the join between the front wing and valence panel from a flange joint ( flanges but up behind the panels and are bolded together) to a lap joint (one panel sits over the other and they're bolted though from the front)
Two questions - what were the sizes of the two different steps and does anyone know when the changes I mention were made?
Stuart
Edit - I should have said my 1977 series 2 parts book does not show any difference in the parts, not does the S1 parts book.
