Author Topic: Relay ID and Schematics For 1979 US Coupe  (Read 4240 times)
Offline movingim
« on: August 17, 2017, 01:39:58 AM »
Hello:
Looking for the Relay IDs and the schematics of the fuse/relay box on the left inner fender next to the air horns. The main wiring diagram does not detail this area and I having some issues with I think is a bad ground.
Jeff
Offline Pineapple91
    • work
Re: Relay ID and Schematics For 1979 US Coupe
« Reply #1 on: January 15, 2025, 07:35:40 PM »
Hi Jeff! If you're still reading this forum and still have your Beta Coupe, here’s my suggestion:
The fuse/relay box on U.S. models is typically near the driver-side inner fender, next to the air horns. Check for part numbers on the relays—those can often lead to identification online or through enthusiasts. Also, clean and secure all grounds; bad grounding causes plenty of electrical headaches in these cars.  ;)
