Author Topic: parts needed  (Read 10076 times)
Offline DARREN BETA. SPYDER
  • beta spyder
parts needed
« on: September 06, 2017, 10:31:19 PM »
hi guys , what alternater would i need for a 2l i.e coupe ? thx
Re: parts needed
« Reply #1 on: September 07, 2017, 04:46:36 PM »
Hi Darren
That would normally be a Bosch 65 Amp item, but have a look at the Beta Boyz options including the small race item that puts out 65Amps. Other wise you will be looking to have an original Bosch unit refurbished typically new bearings and a new regulator/ brush pack.
  • beta spyder
Re: parts needed
« Reply #2 on: September 07, 2017, 07:18:13 PM »
thx , i was looking at betaboys alternators , but this note was with it (Some modification to the wiring (including wiring into ignition via the coil) and a little spacing to line up belt required.) , i wanted to have a go at fitting but a little confused as too whether or how it would go with my emerald injection ecu
