Author Topic: Front Strut Mount Bearing Replacement  (Read 35811 times)
Offline Gromit
  • 1979 Coupe 2000
Re: Front Strut Mount Bearing Replacement
« Reply #40 on: January 24, 2024, 02:00:18 PM »
Excellent work Peter in clarifying the two different versions of beta front strut thrust bearing arrangements and providing a definitive photographic record of each along with an accompanying explanation. I think this thread is very nearly finally complete and resolved!
Just to clarify, am I correct in assuming that the aftermarket replacement SKF needle roller thrust bearing itself (SKF AXK 4060 with 60mm OD and 40mm ID dimensions), can only be used as a removable replacement bearing component with the thrust bearing arrangement in the second (lower) of the two photos in your reply #39, showing the lower supporting washer with a centre flange to locate it into the strut upper seat?
From your description the thrust bearing assembly in the first version, (first or upper photo), may be more than just an easily separated snug press fit into the top support washer with the 6 locating lugs and therefore not a serviceable replacement bearing? The Lancia original part number 82303013 thrust bearing part "kit" comes supplied with the bearing already mounted inside the top washer with 6 locating lugs as well as the lower thrust wafer thin flat washer and rubber seal, but not the lower flanged washer.
If that is the case, I may need to return the two replacement needle roller thrust bearings if they cannot readily be fitted into the top washer support housing, should the need arise in future. Not good news if that is the case for other Beta owners, with the first photo thrust bearing arrangement, searching for a replacement needle roller thrust bearing solution, given the scarcity of the Lancia OE parts, specifically #82303013 for the first version and whatever the Lancia part number is for the second thrust bearing version (Lancia OE part # 82372832?).
It also underscores the need to NOT leave the Beta front strut needle roller thrust bearings unserviced for too long, (cleaned and regreased), such that any lubricating (preferably) waterproof grease goes so hard and dry as to lose all of its lubricating qualities, resulting in the bearing needle rollers eventually being ground into a paste and causing the steering to become very heavy and difficult to drive. Because sourcing a replacement solution could well prove difficult!
Andrew
« Last Edit: January 24, 2024, 02:37:33 PM by Gromit »
« Reply #41 on: January 24, 2024, 02:29:16 PM »
Hi Andrew
You are correct the first type will not split, I tried and it will deform the bearing if you try. The folded over securing lip is too big to allow the metal cased bearing to pop free, which is a shame. I measured the second type and the OD is 58mm, not 60, internally it is 40mm. Interestingly the second type has a plastic holder for the needle rollers whereas the first type has a metal holder.
Oh the joys of old cars eh?
« Reply #42 on: March 08, 2026, 03:03:12 PM »
Resurrecting this old thread I have a problem that I seem to not have the needle roller thrust bearing in one of my 2 front struts that I am refurbishing.
On the nearside there was a needle roller thrust bearing retained the "cup" that sits in the top spring housing and a steel plate on the other side (top mount side).
On the offside there is the same arrangement but missing the needle roller bearing!!!
The bearing I have is 58mmx40mmx2mm. The SKF is 60x40x3 so no good.
Is there a source for this 58mm OD bearing??
« Reply #43 on: March 08, 2026, 03:29:03 PM »
Hi Tim
Is this what you after?
Not new but serviceable, can post it if you would like?
« Reply #44 on: March 08, 2026, 03:31:50 PM »
Hi Peter, thats it!
I will email you.
Tim
« Reply #45 on: March 08, 2026, 04:52:18 PM »
Tim,
I have a pair of SKF AXK4060 bearings not fitted yet.
I can't recall where I got the info to buy these, but they appear to
match your dimensions.
« Reply #46 on: March 08, 2026, 04:55:25 PM »
Those are 60mm OD, not 58mm
« Reply #47 on: March 08, 2026, 05:14:18 PM »
Tim,
Thanks Nigel but as Peter says those will be too wide for the housing. And 3mm thick vs 2mm original although maybe that is not critical....
« Reply #48 on: March 08, 2026, 05:20:18 PM »
Ah yes Peter, the clue is in the part number!
At some stage in the distant future I'll check them out.
« Reply #49 on: March 09, 2026, 02:46:25 PM »
Now for a more esoteric problem after finding the reticent bearing under my car intact(!) I noticed its thrust washer which had not gone walkabouts was cracked.
So,, Anyone have a spare - it is 58mmOD so a later car version. Seem a non stock item so will come from breaking a car.
« Last Edit: March 09, 2026, 02:49:30 PM by lancialulu »
Offline stableblock
« Reply #50 on: March 11, 2026, 07:54:15 AM »
These guys (no connection)  https://www.stephensgaskets.co.uk/laser-cutting  might be persuaded to laser cut and tumble some from hardened stock.
« Reply #51 on: March 11, 2026, 08:58:16 AM »
I think I have found a solution ordered SKF washer 40x60x1 and will take 1mm off radius.... Do you have a lathe Peter (aka Stableblock)?
Offline stableblock
« Reply #52 on: March 11, 2026, 09:01:59 PM »
Sadly, no. You could try sandwiching between two plywood discs (cut out with a hole saw), and spinning up with a drill against a smooth file, emery paper etc to reduce the diameter a bit.  Alternatively you might find it doesnt matter and will fit - its years since I had mine apart. Let us know.
« Reply #53 on: March 11, 2026, 10:06:06 PM »
The problem is and why the dimension is critical is the washer fits inside the retaining cup.
« Reply #54 on: March 12, 2026, 08:16:56 AM »
The last time I had this problem the guys at the Bucks Heritage railway Centre put the part on their lathe for a drink. So ask a local car club who has the lathe?
