Author Topic: With reference to Eric Weston's Guide to molding a Beta...  (Read 2798 times)
Offline droptop
« on: June 02, 2018, 07:08:22 PM »
The flywheel from a Delta turbo is recommended but is it the 1600 or 2000 Delta or are they the same?
Rust never sleeps
Re: With reference to Eric Weston's Guide to molding a Beta...
« Reply #1 on: June 03, 2018, 08:53:36 AM »
My 1985 Delta turbo carb was 1600 and I’m pretty sure the later i.e Turbo was the same.
« Reply #2 on: June 03, 2018, 09:19:00 AM »
I used the 215mm diameter item from the 1600 and drill the bolts holes out, but as long as you have a clutch that matches no reason not to use a lightened flywheel for an 8V Integrale with a 228mm clutch
Offline droptop
« Reply #3 on: June 03, 2018, 06:51:40 PM »
Thanks Eric.
That'll actually be easier to find!
Rust never sleeps
