Author Topic: wheel hub thread pitch ?  (Read 7500 times)
Offline TreviDash
« on: July 27, 2009, 05:26:40 PM »
Does anyone know, or able to measure the road wheel bolt thread pitch?
Thnaks.
'84 Alfa 33 Gold Cloverleaf
'92 Daimler Six
Offline rachaeljf
Re: wheel hub thread pitch ?
« Reply #1 on: July 27, 2009, 11:10:07 PM »
M12 x 1.25
Hey, my first proper post/answer!
Cheers R
Offline TreviDash
« Reply #2 on: July 28, 2009, 02:47:28 PM »
Cheers, and Welcome!
So it's a 12mm diameter bolt with a 1.25mm thread pitch.
I've had a measure since (I don't have thread pitch measurer, and swore they were different to my Alfa 155 as they din't fit Beta hub...) so the rest of the detail is:
17mm hex head.
The longer 'alloy wheel' bolts are length 56mm, having a 35mm shank and a 22mm thread.
* goes for a lie down *  :D
'92 Daimler Six
« Reply #3 on: July 28, 2009, 08:38:41 PM »
Just to add a little more info to this thread, you do have to be a bit careful if you are using the Beta wheel spacers with original Cromadora wheels, I was not happy with how far the wheel bolts screwed into the hub if they were being fitted.  Bolt manufacturers stated at least 8 full rotations to be properly secure and I found that the bolts on my car with spacers they were doing four/five at best.  As they are quite an important part to keep on the car I opted for longer wheel bolts, but did have to turn them down 5mm because I could not buy the right length from the start and the next size up (45mm I think) went in too far and locked up the whole hub.
If you want spacers and need exact measurements just shout
