Thanks for the comments Andrew. Yes,i'm enjoying the project so far!
One of my questions fell into the category "why did I ask that?"...... i.e. the fuel pump! I refered to a recent post for all the answers!
I've ordered a Huco 133010 for 45 quid,should arrive before the weekend I hope.
This new pump will go engine end.
I popped into a local factors this afternoon and found a Wix metal inline filter which will,
very convienently,fit into the ,now unused, old pump bracket at the rear, along with some new
8mm gates fuel hose.
As the outlet from the tank is 13mm I will probably make up a reducer in copper to bring it down to
the 8mm on the rest of the system.
I've now blanked off all the tank pipes,de-rusted the outside-top of the tank,and poured in a 3 to 1 mix
of brick acid [15 litres]which i'm expecting to take a while,with regular turning to get to each part of the inside.
Depending on the result, I may well do it again,either with the same stuff or something stronger.
So, with the metal filter at the back, I'll fit a 'normal-for-carb' plastic jobby at the front between pump and carb.
I'l also be installing an inertia switch,as it seems a really good and safe thing to do. Thanks Kevo and Eric for noting that.
To mangocrazy and betaveloce, did you guys retain the return-to-tank option?
Much regards
