Author Topic: How does the Interior Windscreen trim fix?  (Read 2961 times)
« on: April 24, 2020, 08:16:26 AM »
Hi Beta experts
I have a car to build and need to know how does the Interior Windscreen trim fix? Does it go on before the bonded screen is put in? Does the pillar trim have to be in place first?
This is for a beta Spyder S2
Thank you
Re: How does the Interior Windscreen trim fix?
« Reply #1 on: April 24, 2020, 10:23:04 AM »
Hi Eric
Before I believe. I had to take my screen out after it was fitted at the body guys place because of this mistake.....
Offline Ammy
« Reply #2 on: April 24, 2020, 04:35:04 PM »
Do you not wrap the seal around the screen together with a long piece of  string,   offer the screen to the outside of the body and then pull the string to bring the seal to the inside ?
« Reply #3 on: April 24, 2020, 05:37:25 PM »
Hi Ammy
I have a bonded screen with a Stainless insert to fit. No rubber seal. On the inside of the car is a plastic trim with clips that I think from Peter's comment needs to be fitted before the screen is bonded in.
More answers welcome although I think Peter is correct.
« Reply #4 on: April 24, 2020, 07:59:17 PM »
Hi Ammy
The reusable rubber seal was used on very late cars from what I know and the screens are slightly smaller to accommodate the seal. Personally I wish they were all that way, but sadly not the case.
